ProjeQtOr free project management software - [SOLVED] Import automation - ProjeQtOr
25 Jun 2023 12:02 #1 by jmmbb
Import automation was created by jmmbb
To use automatic import, the files must be placed in the directory provided in the automation tab.
However, how are the types of objects used identified? In the file name?
What naming rule should be used?
25 Jun 2023 12:46 #2 by babynus
Replied by babynus on topic Import automation
Name of files should be CLASS_TIMESTAMP.csv
CLASS is the class name of the object
TIMESTAMP will be used to sort files to be sure to import then in correct order.
Examples :
TICKET_20230625124500.csv
ACTIVITY_20230625124600.csv
25 Jun 2023 13:00 #3 by jmmbb
Replied by jmmbb on topic Import automation
Works fine !
Thanks a lot !
