ProjeQtOr free project management software - [SOLVED] Knowledge Management - ProjeQtOr
29 May 2023 16:49 #1 by LEADER
Knowledge Management was created by LEADER
Is it planned to implement the knowledge management based on the documents stored into Projeqtor for projects, or problem solutions or best practices ?
Thank you in advance for you response.
Bests regards,
30 May 2023 09:33 - 30 May 2023 09:34 #2 by Arkhanje
Replied by Arkhanje on topic Knowledge Management
Hello !
Could you be a bit more specific about what you expect?
What do you expect from ProjeQtOr? That we created a collection of best practices for using ProjeQtOr? practical for whom? Project Manager? team member? Supervisor ? what domain? agri-food? industry? construction? ... Proposals of solutions ok, but for what type of problem? yours ? those of the neighbors? clients? for who? France? Japan? Russia?....
Try to explain in more detail what you want.
Last edit: 30 May 2023 09:34 by Arkhanje.
The following user(s) said Thank You: LEADER
15 Jun 2023 07:48 #3 by LEADER
Replied by LEADER on topic Knowledge Management
Effectively you cannot give an answer without details of my request. But I found the solution with the management of documents. We can manage types, approval, versions and we also can apply filters to select type of documents.
Thank you
