ProjeQtOr free project management software - The problem with the assignments - Page 3 - ProjeQtOr
24 May 2023 09:27 #13 by Tatiana
count|sum    |start     |end       |
    1|0.81250|2023-05-16|2023-05-16|The result in the attached file
24 May 2023 10:10 - 24 May 2023 10:13 #14 by babynus
Sure there is an issue.
The sum of work is 0,8125 days (6.5 hours).
To try and fix :
=> Be sure to use the latest release (V10.3.5). Migrate is needed.
=> Go to the activity
=> Update left work for assignment with too many real work displayed (you can add 1 day / remove one day)
This should fix the value.
Last edit: 24 May 2023 10:13 by babynus.
01 Jun 2023 03:29 #15 by Tatiana
Morning,
We have updated our system to version V10.3.5
Yes, it is working:
However, it does not fix the problem in general. Do I need to do it manually always? Are you going to fix the bug?
09 Jun 2023 15:06 #16 by babynus
What do you mean
There is no automatic fix for this issue, possibly generate on an old version.
As long as I know, there is no remaining bug.
Data entered on V10.3.5 are correct.
