ProjeQtOr free project management software - ProjeQtOr and planning management by duration - ProjeQtOr
17 May 2023 11:40 #1 by iFlorian
Hello everybody,
It is difficult for me to make my community join ProjeQtoR, is it possible to set up ProjeQtOr to use it at first only as a planning management by duration?
I know that this is not its purpose, but a smooth adoption is better than abandoning the software.
In particular, put a little more flashy colors on the activities without assigned loads?
Are there any pre-settings for using duration planning?
Best regards,
Florian
“Be a yardstick of quality. Some people aren't used to an environment where excellence is expected.” ~ Steve Jobs
"...and while some may see them as the crazy ones, we see genius, because the ones who are crazy enough to think that they can change the world, are the ones who do." ~ Think Different
18 May 2023 13:07 #2 by babynus
Just change default planning mode on Activities Types.
19 May 2023 23:24 #3 by iFlorian
Hello Babynus,
Thanks, I've update the activity type with manual planning, but... with this type of activity, why it is not possible to use graphical view to change the period by slides moves ?
I see it is possible to change the end date with fix duration with a click...
Best regards,
Florian
22 May 2023 09:43 #4 by Arkhanje
hello
only regular and fixed duration planning modes can be modified on the Gantt using "handles" (on both sides of the bar for regular and on the right for fixed duration). To move the order of the tasks you have the wbs list.
However, we note the ideas for ergonomic improvements directly on the gantt!
