ProjeQtOr free project management software - Test case and sessions management - ProjeQtOr
01 May 2023 10:46 #1 by cmarti
Hi everybody,
This item has probably been asked and answered a ton of time, but I can't find the answer.
I would like to do the following points in order to check the evolution of the verification of the object under test prior to its launch to prototyping.
  1. Definition of all the tests needed to verify its behavior against its requirements (this is clear and easy)
  2. Having its estimated work summarized into a "parent object"
  3. List all the test cases into a test plan - is it the test session here?
  4. Have a log of all test sessions launch over the test plan - I have here a big confusion in between the concept of test session and test plan for ProjeQtOr.
  5. Have a way (e.g. with the automated integration files) to import the test results from the non-regression tool manager (e.g. Jenkins).
  6. Have a summary report (could use the API if needed) that indicates by week the evolution of the test sessions (which by the way are at least done daily, somethimes more).
    1. The report would ideally have the number of tests passes, failed, blocked, non executed. All stacked to obtain also the evolution of the number of test cases.
I hope that my description is clear, and obviously that we can somehow do it on the tool
Thank you for your help.
02 May 2023 14:33 #2 by babynus
    It is the test session
    Yes, It is the test session
    It is the "test case run" on the test session
    You can import "TestCaseRun" through import or through API
    You'll have to build the "history", as I don't think we have such report
      You'll find it on test session and several reports, but without "history"
30 May 2023 11:38 #3 by cmarti
Thank you Babynus for those explanation.
But I'm still a bit in the dark here.
Is there a part of the documentation giving an how-to or example of using the test cases, test sessions and test runs?
I've also tried the test session summary, but I can't choose the test session , non is visible. I have the warning sign but without any information helping me to solve that missing item
Finally I would like to add some information on the test run like the revision of the version control used for the run, or a seed (we are using randomized tests).
Is it possible to do that? I can't find it on the customization plug-in.
Thank you
09 Jun 2023 14:57 #4 by babynus
User manual is quiter explicit (manual.projeqtor.org/html_en/Requirement....html?#test-sessions)
We also provide some specific document during training sessions that gives accurate and pragmatic information...
No
