ProjeQtOr free project management software - [SOLVED] Transform products into components - ProjeQtOr
27 Apr 2023 18:01 #1 by CSO_Arnaud
Do you have tips or does he exist a function to transform a product and product versions into a component and component version?
Goal : don't brake and have to redo all links between projector objects and products.
Thanks in advance
28 Apr 2023 09:07 - 28 Apr 2023 09:08 #2 by Arkhanje
hello,
No, unfortunately this feature does not exist and we are not planning to do so.
Maybe playing with export/import..
Last edit: 28 Apr 2023 09:08 by Arkhanje.
28 Apr 2023 09:26 #3 by CSO_Arnaud
Thanks for your feedback
