ProjeQtOr free project management software - MS Project Like --> configuration - ProjeQtOr
04 Apr 2023 17:19 #1 by iFlorian
Hi there,
Today, I made a presentation of ProjeQtOr in a Direction of my Collectivity and it was rejected under the pretext that one could not reproduce the ergonomics of MS Project:
-  to be able to modify the start and end dates directly on the planning line,
- to be able to stretch the tasks directly from the planning.
- to be able to move a task into a subtask graphically from the planning.
Is there any possibility of reproducing this behaviours ?
Obviously, they have a very basic use of the tool: only planning management...
The complaint is that changing the screen or splitting the screen into several parts is a waste of time for them.
It's not easy to get the tool adopted by businesses other than the IT department.
I look forward to hearing from you,
Best regards,
Florian
“Be a yardstick of quality. Some people aren't used to an environment where excellence is expected.” ~ Steve Jobs
"...and while some may see them as the crazy ones, we see genius, because the ones who are crazy enough to think that they can change the world, are the ones who do." ~ Think Different
06 Apr 2023 17:47 #2 by babynus
It is possible for "ragular between dates" tasks
It is possible for "fix duration" tasks
It is possible with D&D and Indent buttons.
Maybe Projeqtor is not "as easy" as MS-Project because it is not a drawing tool.
It is a tool that builds a capacity planning.
