ProjeQtOr free project management software - Left menu and top information - ProjeQtOr
20 Mar 2023 14:20 #1 by loicr
Dear,
On left panel depending i'm using "test" or "production" VM ( same version en system 10.3.0 )
on test version, i'm able to block left panel "ancrage" but not on other VM
On on test version, i've got icon with last log, but not present on production ( emply case on uper right )
I test to click on the AREA and it seems to work ( something like icon not show ? )
i see that in LOG:2023-03-20 10:58:01.841 ***** ERROR ***** [V10.2.3] Cannot create image thumb of size 32 for ../files/attach/attachment_16/image003.png (uploaded file with image extension is not an image, try and delete it)
Sincerely
LR
20 Mar 2023 14:38 #2 by babynus
It really looks like some chache issue.
Be sure to clean the browser cache.
20 Mar 2023 14:51 #3 by loicr
Replied by loicr on topic Left menu and top information
When i copy new version 10.3.1 it say me on both production and test vm that it is impossible to copy some files in VIEW/CSS/IMAGES ....
link ?
it was not the case on previous upgrade in testing environnement.
20 Mar 2023 14:53 #4 by loicr
i force copy in command line sudo cp -r projeqtor \var\www\
and then it work again ... strange !
20 Mar 2023 15:10 #5 by babynus
Possibly an access right issue.
Check your files, sometinmes unzipping retreives right of current user.
The following user(s) said Thank You: loicr
