ProjeQtOr free project management software - [SOLVED] Import Data using csv - ProjeQtOr
20 Feb 2023 18:05 #1 by t107b
Import Data using csv was created by t107b
Hello ProjeQtOr team,
could you please give me a hint/help with the following issue:
during data import using csv, there is "Invalid controls" message mentioning that "NA" is not a valid data_type (numeric,date etc.) for certain fields. What confuses me is the import is used to work without specifiying those fields (most of them hidden and not being used) before 10.X version. I have also checked if these "problematic" fields are required, but they are not.
Thanks in advance!
21 Feb 2023 15:38 #2 by babynus
Replied by babynus on topic Import Data using csv
Please give more exemple : screenshots, import files, ...
05 Mar 2023 13:25 #3 by t107b
Replied by t107b on topic Import Data using csv
the problem was caused by the library which converted 'NA' values to string literal 'NA' while writing R dataframes to cvs. The issue has been solved. Sorry for inconvenience.
