ProjeQtOr free project management software - [SOLVED] [Projects] Proposition tab in custom fields not visible - ProjeQtOr
17 Feb 2023 12:03 #1 by Cpt_Jabberwock
Hello,My chief while printing one of the project noticed some fields  "Strength", "weaknesses", etc that were not visible on the projetcs while doing them
But when I go check using Customization, It is hidden by default and cannot be used and he was thinking that he could use them to have some way to tell if a project could be difficult to do or not, etc
Could anyone tell me what it is and how to show them ?
18 Feb 2023 18:03 #2 by babynus
These fields are visible for Projects of type "Proposale".
They are hidden for other types.
The following user(s) said Thank You: Cpt_Jabberwock
