ProjeQtOr free project management software - [SOLVED] Specific group for LDAP connections - ProjeQtOr
12 Jan 2023 10:49 #1 by Infra_Kev
Hey
I have a problem with LDAP, I want to do a filter with a specific group : "PROJ_USERS".
But when I try to modify paramLdap_user_filter in parameters.php i have no idea what to write.
I try sAMAcountName=%USERNAME%,MemberOf="PROJ_USERS" or change to (&(objectclass=person)(memberof=PROJ_USERS) but it doesn't work.
help please
12 Jan 2023 11:41 #2 by Plucks
You are not supposed to modify the parameters.php file.
With an administrator profile, you should use Global parameters, Authentication tab, and Ldap management parameters to change or use any filter of your choice.
12 Jan 2023 12:12 #3 by Infra_Kev
Yes i know, but i have a bug with the save and my file parameters.php doesn't update
12 Jan 2023 18:13 #4 by babynus
I think syntax should be something like
(&(sAMAccountName=%USERNAME%)(memberof=PROJ_USERS))
Bur best is to request an AD expert for correct syntax
13 Jan 2023 09:20 - 13 Jan 2023 09:31 #5 by Infra_Kev
it doesn't work
2023-01-13 09:18:14.357 ***** ERROR ***** [V10.2.1] ERROR *****
2023-01-13 09:18:14.359 ***** ERROR ***** [V10.2.1] on file 'C:\...\projeqtor\model\UserMain.php' at line (1547)
2023-01-13 09:18:14.360 ***** ERROR ***** [V10.2.1] cause = ldap_search(): Search: Bad search filter
EDIT : ok, I did a fault hehe
2023-01-13 09:22:56.882 ===== TRACE ===== authenticate - Filter error : ldap_search returned no result for filter (& (sAMAccountName=XXX)(MemberOf=PROJ_USERS)))
2023-01-13 09:22:56.884 ===== TRACE ===== Login error for user 'XXX'
Last edit: 13 Jan 2023 09:31 by Infra_Kev.
13 Jan 2023 16:46 #6 by babynus
Here is some syntax found on the web.
Try something like that.
(&(objectCategory=Person)(sAMAccountName=%USERNAME%)(memberOf=cn=CaptainPlanet,ou=users,dc=company,dc=com))
