ProjeQtOr free project management software - [SOLVED] Test Sessions & Test case - ProjeQtOr
22 Dec 2022 14:38 #1 by kobetsu
Seems I found functionality of TAGs which was not available normally.
I added custome field to the document with name tags and db field 'tag' and new filed with special functionality was added.
Can you tell me more what is orginal purpose of this functionality ?
23 Dec 2022 10:42 #2 by babynus
Replied by babynus on topic Test Sessions & Test case
This was designed for Documents.
Be able to pout some tags and search documents from tags, with quick filter or advanced filter.
As you discovered, the system is designed to be generic, and can be extended to any object.
23 Dec 2022 10:48 #3 by kobetsu
Replied by kobetsu on topic Test Sessions & Test case
thanks
