ProjeQtOr free project management software - ODBC 64 bit and MySql 32 bit - ProjeQtOr
14 Dec 2022 18:30 #1 by NoCompagnie
I have a 64 bit PC and 32 bit MySql. MySql 64 ODBC driver does not work. I know there is a technique to install the 64 driver to work with the 32 bit MySql. Do you have any instruction to help IT to do the installation?
thank you
15 Dec 2022 16:45 #2 by babynus
You can just install the 32bits driver (32bits applications work fine on 64bits CPU, reverse is not true)
