ProjeQtOr free project management software - [SOLVED] Resources, users and LDAP - ProjeQtOr
22 Nov 2022 14:35 - 22 Nov 2022 14:38 #1 by matthieu.froment
I am now at a stage where I really want to use Projeqtor more globally for our team.
Projeqtor is connected with our LDAP.
For new projects, I am creating planning with resources. I so declare resources in Projeqtor. These resources are in fact a "never connected user"
I was wondering, if there is a possibility to bind afterwards a manually created resource to an account created after the first connection with an LDAP account ?
* workaround 1 : request a first connection from all the people that will work on projects. Not so simple !
* workaround 2 : I can declare my resources as a user afterwards but I will have users coming from LDAP and local users. I really prefer to have only LDAP accounts.
Many thanks for the feedback or your ideas...
Last edit: 22 Nov 2022 14:38 by matthieu.froment.
22 Nov 2022 15:00 #2 by babynus
Replied by babynus on topic Resources, users and LDAP
Just use your "workaround 2, and check "comes from LDAP" is user screen.
The following user(s) said Thank You: matthieu.froment
