ProjeQtOr free project management software - [SOLVED] predefined note - ProjeQtOr
18 Oct 2022 12:03 #1 by rmiroff
predefined note was created by rmiroff
I created a predefined note in an activity. The note does not appear after validation
Is there a BUG or a particular manipulation to display the notes automatically.
I am on version 10.0.6
I'm about to upgrade to the new version
Does this fix it?
19 Oct 2022 10:27 #2 by Arkhanje
Replied by Arkhanje on topic predefined note
it works well for me. Did you save your predefined note with a type? are you sure you are on the right type?
When you say "does not appear"... where? In the list box of the predefined notes screen or in the drop-down list of predefined notes when opening the notes pop-up?
19 Oct 2022 13:58 #3 by rmiroff
Replied by rmiroff on topic predefined note
I have created a scheduled task under an activated and a type.
I just updated with the new version.
I have created new activities but the notes do not appear.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
This browser does not support PDFs. Please download the PDF to view it: Download PDF
20 Oct 2022 10:15 #4 by Arkhanje
Your capture does not show much with respect to the notes.
Just as a reminder, you must add a note by clicking on the icon and select the note template you want to use !
20 Oct 2022 10:26 #5 by rmiroff
Thank you
