ProjeQtOr free project management software - [SOLVED] Change project cost when in progress - ProjeQtOr
28 Sep 2022 09:07 #1 by matthieu.froment
I made a mistake when creating a project, especially in the "cost" field. For sure, the margin calculated is wrong. Now my project is in progress.
Is there a way to change the value afterward ?
28 Sep 2022 17:25 #2 by Plucks
Hello !
Did you try to fix the costs on your resources function and cost ?
29 Sep 2022 15:58 #3 by matthieu.froment
Yes, all my ressources have a cost.
To explain my problem (I am probably using the functionnality the wrong way)
I have created a fresh new project with tasks : screenshot "before.png". All is saved correctly
In order to monitor the global margin, I enter the price given to the client : screenshot "during.png" in the cost field
I save what I do and I have the screenshot "after.png".
The cost field is now grayed and I cannot modify it anymore...
This example project is in a "qualified" state with the "under construction" flag on !
30 Sep 2022 10:04 #4 by Arkhanje
Check that you may not have activated the parameter that automatically calculates your validated cost
30 Sep 2022 13:49 #5 by matthieu.froment
I checked the parameters, and all is set to No.
03 Oct 2022 10:04 - 03 Oct 2022 10:04 #6 by Arkhanje
Hi !
In this case it is surely the consolidation of the validated work that you have put on always or on if set.
The fields become read-only and will automatically update from the lowest element of the WBS to go all the way up to the parent project.
Global parameters > planning > automation > consolidate validated work & cost
If you do not want to consolidate this data, set this parameter to "never", in this case the validated data is not uploaded automatically
Last edit: 03 Oct 2022 10:04 by Arkhanje.
