ProjeQtOr free project management software - [SOLVED] Define/assign responsible to Project - ProjeQtOr
31 Aug 2022 21:30 #1 by MocniMax
In our current Project management, we have one user/resource assigned as a responsible for a Project. Same responsible is automatically assigned as a Project member which can have Project tasks allocated, if there is any what is not mandatory.
Is there a way in ProjeQtOr to do the same, to explicitly assign an user/resource to a Project as responsible one?
01 Sep 2022 09:35 #2 by Arkhanje
hello,
In global settings > planning > automation > ... you have several parameters that could correspond to your needs
auto assign responsible to activity
auto set responsible if single resource
auto allocate manager to the project
auto set responsible if needed
and auto assign responsible to activity
As a reminder : allocation for project - assignment for activity.
01 Sep 2022 09:44 #3 by MocniMax
Thanks for fast reply, will check all of them and see which one suits our needs the best.
