ProjeQtOr free project management software - [SOLVED] Timesheet ->go to timesheet directly button for each resource ? - ProjeQtOr
22 Aug 2022 16:56 #1 by iFlorian
Does-it possible to have a button "go to timesheet for this assignment"  not only for myself but each user assigned to the activity ?
Here we see that we have only one arrow button for one resource (namely myself)
Due to ( external or not) resources that do not connect to the application but perform activites, so it is me who fills in their tracking timesheet.
Thank you,
Florian
“Be a yardstick of quality. Some people aren't used to an environment where excellence is expected.” ~ Steve Jobs
"...and while some may see them as the crazy ones, we see genius, because the ones who are crazy enough to think that they can change the world, are the ones who do." ~ Think Different
22 Aug 2022 17:22 - 22 Aug 2022 17:23 #2 by babynus
In fact it is the default behavior with stnadard setup for Project Manager.
You may have changed some specific acces rights not to have it work as expected.
Last edit: 22 Aug 2022 17:23 by babynus.
23 Aug 2022 14:04 #3 by iFlorian
Thank you but, In Specific access, the project leader has "All resources"  everywhere on "Access to resource data"  and on the project that I manage, meanwhile, I have only arrow for myself on activities....
Is it a bug ?
Thanks,
Florian
23 Aug 2022 18:20 #4 by babynus
I checked the code, and constraint to see the arrow is "Resource is not a Pool of resource" and current user has acces to Timesheet of the resource.
$listUser=getListForSpecificRights('Imputation');
if(!$assignment->isResourceTeam and isset($listUser[$assignment->idResource])){
Which version of ProjeQtOr are you using ?
Could you reproduce the use case on the Demo ?
24 Aug 2022 14:52 #5 by iFlorian
It's on the last version 10.0.4.
The resources is not a pool and I have acces to the timesheet of resource because if I go to my timesheet, then I can change resource on the screen to fill on the time of this resource.
24 Aug 2022 19:45 #6 by babynus
Can you change the work for the resource on the activity from where you want to acces (but have no button)
