ProjeQtOr free project management software - [SOLVED] Usage of manager field in Project - ProjeQtOr
12 Aug 2022 22:12 #1 by MocniMax
Hi.
I am trying to prepare data of few thousands of Projects with filled up hours to be able to migrate them from our legacy management software (MS Access) to ProjeQtOr and have issues with ProjeQtOr fields mapping and understanding their usage.
One of them is a manager field in Project definition. I am not able to see any relevance and difference if I assign an allocated Project Member user to manager.
What is its actual purpose? The ProjeQtOr documentation mentions it is a manager but nothing about its behavior.
Any help is really appreciated.
16 Aug 2022 11:10 - 16 Aug 2022 11:11 #2 by Arkhanje
the manager is an information field.
You can automate its allocation with a global parameter and you can send the detail of an element thanks to this title.
That's all he can do
Last edit: 16 Aug 2022 11:11 by Arkhanje.
16 Aug 2022 12:08 #3 by MocniMax
OK, thanks for explaining it.
