ProjeQtOr free project management software - Imputation - ERROR unsupported operand types : string / string - ProjeQtOr
20 Jul 2022 14:47 - 20 Jul 2022 15:10 #1 by vba
Hello team,
From this morning, i have this strange error when trying to save my imputation, (V9.5.5)
Note that we've never experience errors with imputation before.
The error appears for every users, for a specific activity. This activity was created yesterday, and imputation done yesterday saved with no error.
The debug set to 4, the full saveImputation log is attached, and the specific errors lines are :
[color=#000000]2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5] EXCEPTION ***** [/color]
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5] on file '/path/to/prj/projeqtor/model/PlanningElement.php' at line (448)
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5] cause = Unsupported operand types: string / string
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5]    => #0 /path/to/prj/projeqtor/model/ActivityPlanningElementMain.php (520) -> save()
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5]    => #1 /path/to/prj/projeqtor/model/PlanningElement.php (1389) -> save()
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5]    => #2 /path/to/prj/projeqtor/model/PlanningElement.php (1420) -> updateSynthesisObj()
2022-07-20 14:06:06.817 ***** ERROR ***** [V9.5.5]    => #3 /path/ro/prj/projeqtor/tool/saveImputation.php (265) -> updateSynthesis()
Any advice (other than recreate and replace the activity) ?
EDIT : i forgot to mention that despite this error, the imputation are correctly saved.
Last edit: 20 Jul 2022 15:10 by vba.
21 Jul 2022 17:37 #2 by babynus
Strange, it seems you have an Activity with planning mode "Fix duration", without a duration defined.
Try and set validated duration.
It should fix the issue.
22 Jul 2022 16:21 #3 by vba
The Activity is set with planning mode "Fix Duration", and a duration is set (btw a start date and an end date, with the caldulated duration).
The issue only occur on this specific activity, fir a specific date (for the time being).
Well, do not not spend more time on this if it not occur anymore in the future.
Thanks for your support.
27 Jul 2022 10:14 #4 by babynus
Ticket #6362 recorded
