ProjeQtOr free project management software - Project selector display - ProjeQtOr
03 Mar 2022 17:10 #1 by IManAsap
how to ensure that the project selector list is displayed in alphabetical order
Thank's
03 Mar 2022 18:05 #2 by babynus
Replied by babynus on topic Project selector display
Project Selector is displayed is WBS order...
So if you really need an alphabetical order, just reorder your project in planning view
08 Mar 2022 10:36 #3 by IManAsap
Replied by IManAsap on topic Project selector display
Good morning,
thank you for your answer, but my need is to be able to quickly find a project in the project selector, in order to select it, given the large number of projects in progress.
08 Mar 2022 11:38 #4 by babynus
When you move the mouse over the project selector, you'll see a magnifying glass on its right.
Use ii to get a list of projects that can be sorted and filters, and then select your project (check button or double-click)
Note that this list accepts multi-selection (with CTRL or SHIFT)
