ProjeQtOr free project management software - [SOLVED] Login in Projeqtor using admin user takes long. - ProjeQtOr
03 Mar 2022 10:00 #1 by chandrashekhar
Hello Friend,
Is there any solution for taking a long time to login in to Projector i.e. more than 2 minutes and 30 seconds?
03 Mar 2022 10:40 #2 by babynus
This is due to some of our server off.
This is fixed.
11 Mar 2022 11:18 #3 by chandrashekhar
Thanks for giving solution, but it worked for two days only and since 06-mar-2022 , It is same thing happening that it is taking long to log in admin user!!
14 Mar 2022 14:36 #4 by babynus
These issues are not occuring any more
15 Mar 2022 05:40 #5 by chandrashekhar
Thanks for reply, I have just checked it , it is taking yet long time if I am logging in using admin!
15 Mar 2022 08:56 #6 by babynus
Try and disable the check version in global parameters.
