ProjeQtOr free project management software - Adjust list field width and latéral position. - ProjeQtOr
22 Feb 2022 09:13 #1 by LaurentC
When a list field is created, how to adjust its width and lateral position ?
private static $_layout has no effect:
<th field="IdStatusPurchasing" width="20%" >${IdStatusPurchasing}</th>
private static $_fieldsAttributes=array...
has also no effect:
"IdStatusPurchasing"=>"mediumWidth",
Thanks in advance.
#L.
22 Feb 2022 18:21 #2 by babynus
You'll see effect of $_layout only if refresh the list disposal.
23 Feb 2022 08:38 #3 by LaurentC
Thanks for your reply, but no effect AFTER having refreshed the page, even with logout/login
23 Feb 2022 10:58 #4 by babynus
Not refresh the page, refresh the list layout
23 Feb 2022 13:42 #5 by LaurentC
I was not speaking about the list window. The concern is about the detail window (see attached picture).
Thanks in advance.
24 Feb 2022 14:21 #6 by babynus
You cannot "adjust" as you expect.
1) If you have 2 fileds on same line (use on noBr attributre), then second field has no name displayed.
2) As you have 2 fields on same line, width of list is automatically adapted to half of the available space.
The following user(s) said Thank You: LaurentC
