ProjeQtOr free project management software - Modify real work - ProjeQtOr
Modify real work
01 Feb 2022 11:14 #1 by luisfv
Modify real work was created by luisfv
Hi:
I have just discovered projeqtor and I am delighted with it. But I just encountered the first problem and I didn't find how to solve it in the manual.
During the tests I added a user that now I want to delete but projeqtor tells me that it can't because that user has real work assigned. And I can't figure out how to modify that real work so I can delete it. Is it possible?
02 Feb 2022 09:03 #2 by babynus
Replied by babynus on topic Modify real work
This user entered real work on Timesheet or directly on tickets.
Use reports or timesheet validation to find on which days and remove the real work.
03 Feb 2022 17:27 #3 by luisfv
Replied by luisfv on topic Modify real work
Thanks! Yes, I have found an entry in the timesheet, deleted it and the problem was solved.
Thank you again
