ProjeQtOr free project management software - Help for Reset Admin Password - ProjeQtOr
28 Dec 2021 05:01 #1 by nauta69
I have installed version 9.3.5 on a cloud hosting. After installation, the system does not recognize the admin user and the message "invalid login parameters" appears. I tried the solution that babynus offered:
Otherwise, update table resource, line for id of admin (default admin is id #1) set "password" to new password (clear text) and "crypto" to null
But it has not worked. I appreciate the help you can offer me.
Thank you
28 Dec 2021 17:23 #2 by babynus
Possibly some php modules are missing on your hosted server.
Can you try and get logs to find the source of the issue ?
(projeqtor log, apache error log, php error log)
28 Dec 2021 18:55 #3 by nauta69
File Attachment:
File Name: projeqtor_...1228.zip
File Size:468 KB
Hi! I attach the log file
29 Dec 2021 12:03 #4 by babynus
You re-run installation on a partially installed DB.
Drop all tables in DB and retry (reconnect as admin/admin).
29 Dec 2021 22:54 #5 by nauta69
Thanks babynus!
Perform the installation again as you indicate and it works perfect!
