ProjeQtOr free project management software - DEFAULT TOP MENU - ProjeQtOr
DEFAULT TOP MENU
13 Dec 2021 18:21 #1 by WE-TIP
DEFAULT TOP MENU was created by WE-TIP
Hello QTOR Community (Qtorian ?),
Is it possible to set a default TOP menu for all users?
The goal is to have the same menu for all users to start the project.
Thank you in advance,
TIP
14 Dec 2021 11:08 #2 by Arkhanje
Replied by Arkhanje on topic DEFAULT TOP MENU
Unfortunately this functionality does not yet exist.
It is a complicated development to settle and expensive in which we do not plan to invest.
ps: on the other hand I like the name of the community!
The following user(s) said Thank You: WE-TIP
14 Dec 2021 14:37 #3 by WE-TIP
Replied by WE-TIP on topic DEFAULT TOP MENU
Thank you for your answer.
I will look if it is possible to modify in hard in the file.
If I find it, I will pass the information on.
Sincerely,
TIP
PS : Qtorian or QTOR Community ?
