ProjeQtOr free project management software - [Solved] How to set access rights for project leaders to see all ressources - Page 2 - ProjeQtOr
10 Dec 2021 11:17 #7 by RoBra81
But in this report you can't see wich projects and activities the are assigned to
14 Dec 2021 09:56 #8 by babynus
Default configuration is that project leaders see resources allocated to their project. This is the case for instance Resource Planning.
This is defined on specific access right "Access on Timesheet for resources" (this parameter is used for other means than just timesheet).
Default value for PL is "His projects", you may change to "All resources"
Other option is to allocated resources to a project the PL manages.
The following user(s) said Thank You: RoBra81
