ProjeQtOr free project management software - [Solved] Filter projects in planning view (gantt) by project property - ProjeQtOr
01 Dec 2021 10:49 - 02 Dec 2021 07:35 #1 by RoBra81
is there a possibility to filter projects in planning view (gantt chart) by properties of the projects like manager, customer code, customer,... - didn't found these fields within advanced filter.
Ronny
Last edit: 02 Dec 2021 07:35 by RoBra81. Reason: Solved
01 Dec 2021 15:32 #2 by Flou
It's not possible to to apply filter only on Project in planning view,.
However you can filter all the same filter in more detail with the advanced filter, but not by project properties.
02 Dec 2021 06:56 #3 by RoBra81
Okay, maybe that's an idea for a later version. The reason why I asked for that is the following: we have several project leaders how have their own projects - I set them to managers for their projects. When doing the planning every project leader shall see all projects but also want to have an overview over his/her projects. That's why I asked for that. Do you have an idea how to reach that requirement at the moment?
Ronny
02 Dec 2021 07:34 #4 by RoBra81
I just found the possibily to select projects in project selection by using filters - GREAT!! That solved my problem!
Great software!
