ProjeQtOr free project management software - Problem using Projeqtor API - ProjeQtOr
25 Nov 2021 14:56 #1 by ProjeqtorRequest
Hello !
I don't know if it's normal, but I have a lot of trouble encoding my data to use a POST request...
ibb.co/QCMh1YM
In the link above, you will see that I use a site to encrypt my data, using my API key.
I use AES-CTR 256
This encryption will be replaced by a function in the language that will call the API, but for my tests, I use this site, but I also did the test with other sites.
ibb.co/6Fxm6zb
In the link above, you will see that I use postman to simulate the request, but I have the same error that many have already had on the forum...
My $aesKeyLength is set to 128
=> debugLog(Parameter::getGlobalParameter('aesKeyLength'));
return 128.
If I use your function AesCtr::encrypt to encrypt , it works, but ONLY with this function... I used lot of website to encrypt datas, and none of them worked ...
Do you know where it comes from?
It seems that this encryption function causes a lot of problems for many users.
Thanks a lot
25 Nov 2021 17:36 #2 by babynus
Replied by babynus on topic Problem using Projeqtor API
If $aesKeyLength is set to 128, encrypting with AES-CTR 256.
You must eitehr encrypt to 128 or change aesKeyLength to 256 (not that this is illegal in some countries)
25 Nov 2021 18:04 #3 by ProjeqtorRequest
Sorry, I cannot edit (I have written a mistake)
I encrypt in 128 and not in 256
That's why I don't understand why it doesn't work
28 Nov 2021 16:17 #4 by ProjeqtorRequest
I'm pretty sure there is a problem with the encryption, it only works with your function, but all the other functions I use (python, websites, etc...) do not give the same result.
The only solution I see is to comment the line that allows decryption, and to use only unencrypted data
29 Nov 2021 08:38 #5 by babynus
Do you use the correct API Key, correspondiong to the user ?
29 Nov 2021 12:15 #6 by ProjeqtorRequest
Yes.. So strange...
Time to create page: 0.074 seconds
