ProjeQtOr free project management software - [SOLVED] Buisness features [9.3.2] - ProjeQtOr
02 Nov 2021 14:12 #1 by Juanbeizh
while exporting test cases into CSV, there is a "buisness feature" item in the Description column, but I can't find a place to define it ...
Does someone knows how to use this field ?
Thanks,
Erwann
05 Nov 2021 17:47 #2 by babynus
Replied by babynus on topic Buisness features [9.3.2]
It is visible on Test Case if feature is enabled in global configuration (tab "Configuration")
The following user(s) said Thank You: Juanbeizh
