ProjeQtOr free project management software - [SOLVED] Retrieving status related info with TemplatePlugin - ProjeQtOr
27 Oct 2021 18:11 #1 by t107b
Hello everyone,
I am trying to retrieve some information related to status - when and who changed status, by using TemplateReport Plugin. But I couldn't find appropriate codes from the available options. Is there a way to implement above mentioned scenario?
Thanks!
28 Oct 2021 11:07 #2 by Arkhanje
indeed, this code does not exist. We cannot retrieve this information since there is no field corresponding to this data that can be retrieved.
The only workaround would be to call up the history in your report ... but that can be a big hassle.
The following user(s) said Thank You: t107b
