ProjeQtOr free project management software - Installation/configuration issue - ProjeQtOr
01 Sep 2021 17:05 #1 by THOMAO
I am trying to install for the first time ProjeQtOr and I am facing some issues.
Environment
- Windows server 2016 64 bits
- Wampserver (Apache 2.4, MySQL 5.7.31, PHP 7.3.21)
I copied the projeqtor folder in the www folder and when launching "http://localhost/projeqtor/view/main.php",  the configuration page.opens. I fill the appropriate information (database name, username, password) and leave the other default values.
When clicking on save configuration, nothing happens. No log files is created .
Thanks for your help
03 Sep 2021 10:26 #2 by Flou
have you some error message ?
and also in your browser console have you an error ?
can you show a screenshot of your page of configuration before save ?
07 Sep 2021 11:12 #3 by babynus
Check for error in Apacxhe or in PHP error log file.
Most current issue is that your php user don't have rights to write on projeqtor folder (sometimes unzipping sets folders as readonly).
