ProjeQtOr free project management software - [SOLVED] Connection problem on projeQtOr V9.0.4 - ProjeQtOr
02 Aug 2021 11:58 #1 by safioumou
Hello everyone
I need help on this error that I encountered since Friday when I launch the application to connect, nothing is signaled in the logs
SQLSTATE[08006] [7] could not connect to server: Connection refused Is the server running on host "127.0.0.1" and accepting TCP/IP connections on port 5432?
02 Aug 2021 15:25 #2 by Flou
check that your configuration is correct, look in your parameter.php file that it is the correct port.
02 Aug 2021 19:09 #3 by safioumou
thank you very much for the reply
but all the configuration is good I have been using this instance for 5 months.
03 Aug 2021 15:21 #4 by Flou
Okay , can you try to update and test if you have already this issue it's possible is already fixed in latest version available.
03 Aug 2021 19:26 #5 by safioumou
i dont think this due has an update as i have the same version on another instance
09 Aug 2021 13:10 #6 by babynus
This seem to be a Firewall blocking.
Try and disable firewall to check it works fine. If so, you'll have to add rule in firewall to allow local access through http
