ProjeQtOr free project management software - Timesheet validation and validation of days for activities/project - ProjeQtOr
22 Jul 2021 08:29 #1 by navver1990
Hello ,
My doubt is regarding the Timesheet validation and below are my observations.
1) After doing the Timesheet validation,validation days should get filled automatically for those days which are validated which is not happening.How to do it automatically.
Manually will be difficult to check activity and fill validation days in progress section.
2)After unvalidating the timesheet ,real work should get removed from resource timesheet as well as activity progress section which is not happening.What i have observed is,after unvalidation,real work is still there in activity progress section for those particular mandays.
Please update me for any info regarding the above queries.
Thanks,
Naveen
22 Jul 2021 09:29 #2 by Arkhanje
After performing the timesheet validation, the validation days should be filled in automatically for the validated days, which does not happen. How to do it automatically.
The days that you validate are well filled, since you validate them... So you want to fill the fields again with the same values ​​???
Validation dates have no impact on planning (except with certain planning modes), nor on your resources. These dates are there to record your wishes and are uncorrelated from the imputations.
After you have disabled the timesheet, the real work should be removed from the resource timesheet as well as the progress section of the activity that is not happening. What I have observed is that after devalidation, the real work is still there in the activity progression section for those particular Mandays.
If you do not validate, or invalidate an imputation week, it means that you are not satisfied with the hours entered by your resources, but that does not mean that they are false.
This will just allow your resources to be able to modify their charges for the week. Validation will simply block the week.
It is REAL Work. therefore NO, we do not erase an entire week of reality on Friday because the allocations of resource A do not suit you on Monday.
22 Jul 2021 11:26 #3 by navver1990
Hello ,
"The days that you validate are well filled, since you validate them... So you want to fill the fields again with the same values ​​???"
Regarding the above response,I was asking about suppose i have validated timesheet for 1 days,then in the progress section of the activity,validated days should get updated which is not happening.Please refer to the attached screenshot.In that ,i have filled timesheet for 1 man day and validated but highlighted yellow part validation field is not getting updated.
Thanks,
Naveen
22 Jul 2021 11:31 #4 by babynus
Validated work is not the sum for real work that is validated.
Validated work is the initial work (estimate / sold / baseline)
