ProjeQtOr free project management software - Create report by using SQL command and put into [Follow-up] - [Reports] function - ProjeQtOr
17 Jul 2021 06:41 #1 by navver1990
"Just define your own php report and store it in /report folder.
Then add new line in report table : you'll have access to it in the reports screen, like any standard report, and will be able to manage access rights for it.
NB : you can use SqlDirectElement functions to run you SQL quer (not an advised practice, but can be used)"
I got the above info from one of the query.Please guide for the steps.I wanted to generate reports with customized fields only
