ProjeQtOr free project management software - Incorrect connection parameters - IIS - ProjeQtOr
09 Jul 2021 10:52 #1 by rature
Configuration :
Projeqtor 9.2.1
Windows server 2016
IIS 10.0
PHP 7.4.21
MySQL 8.0.25
Hello, I'm here to tell you my problem.
After having a lot of problems configuring PHP on IIS, I finally got access to the Projeqtor interface.
Once the configuration is done, I want to connect to the application with the admin login.
The database is well populated, all tables seem to be correct.
However, when I want to connect I get the following message:
In the console of my browser I observe that the resource saveDataToSession.php returns an error 404.
I also went to see in the logs of Projeqtor and here is the message it gives me:
2021-07-09 10:26:21.304 ===== TRACE ===== Login error for user 'admin'
My database is configured in utf8_general_ci.
I confess I am blocked and I don't understand where the problem comes from.
I hope you can give me an answer!
09 Jul 2021 12:49 #2 by babynus
Please check for errors in your IIS server that can explain 404 errors
09 Jul 2021 14:00 - 09 Jul 2021 14:03 #3 by rature
I looked in the IIS logs and this is what I found (see in attachments)
Unfortunately, this doesn't help me much. When I enter the full path of the files in my browser I can find them but it doesn't help me to find out how to fix the connection problem...
File Attachment:
File Name: logs.txt
File Size:4 KB
Last edit: 09 Jul 2021 14:03 by rature.
