ProjeQtOr free project management software - Difference between responsible part in Treatment section - ProjeQtOr
07 Jul 2021 12:10 #1 by navver1990
Below are some of my doubts
1)What is the purpose of Responsible part in Treatment section.After adding any resource as responsible ,it is not coming in resource allocation section then what is the purpose
of responsible resource ?
2)How to make Activity ID Sequential while creating activities ?
3)If a resource fills any timesheet,then its progress is getting reflected in Project status before even timesheet validation.This is an issue as after validation only progress should be applied in project.
Thanks,
Naveen
08 Jul 2021 09:42 #2 by Arkhanje
On the elements in general, the responsible has only administrative value.
Only on tickets where the responsible designates the person who actually works on the latter.
the id is indeed sequential. It applies to the creation on each of the elements and follows.
Now it's a collaborative tool, so if one of your collaborators creates an identical element at the same time as you, your sequence will indeed be disrupted.
You have the references to overcome that.
I'm not sure I understand.
The working time entered by the resources is effective and real. It is therefore indicated immediately. We offer capacity planning and reality is a key element for monitoring.
Ask yourself that the carryover of this real on the project, only appear if a person has validated the work of these resources?
