ProjeQtOr free project management software - Issue connection with LDAP - Page 2 - ProjeQtOr
24 Jun 2021 17:41 #7 by p.Paimboeuf
my administrator asks in which file put this command :
the one in "model" folder or the one in "view" folder ? both ?
there is a third but writed parameterS in config folder.
24 Jun 2021 17:56 #8 by babynus
Replied by babynus on topic Issue connection with LDAP
Open file tool/parametersLocation.php
Here is location of file parameters.php that you must change
NB : default location is ../files/config/parameters.php, but you should change this to put this file out of web reach
30 Jun 2021 17:25 #9 by p.Paimboeuf
no, it doesn't work...
is it possible to put parameters directly in the file?
11 Aug 2021 15:50 #10 by bvd
Replied by bvd on topic Issue connection with LDAP
To fix, you need to put the value into simple quotes : $ldapFormatUri='false';
Then restart your web server
It should work
