ProjeQtOr free project management software - [SOLVED] Gantt Chart not showing Predecessor and sucessor elemets on Report - ProjeQtOr
27 Apr 2021 08:44 #1 by tschmidt
i have a problem with the Gantt chart showen at "Follow-Up" -> "Reports". When I go to "planning" and then select "gantt" I am able to generate a Gantt chart but all the arrows leading to other elements like predecessor and sucessor elemts are missing wich makes it unusable. Am I missing something? Or is this a bug?
The version I am using is 9.1.2.
I put a picture of the chart im getting in the attachments.
Thanks in advance.
T. Schmidt
27 Apr 2021 09:20 #2 by babynus
It is a know limitation of this report, that will never be removed.
To have a clean and complete report of Gantt chart, use print / pdf export function on planning screen.
The following user(s) said Thank You: tschmidt
27 Apr 2021 09:25 #3 by tschmidt
Ok thanks.
I was aware of the print function on the planning screen but it misses the headline the report provides.
Stil lots of thanks for the quick reply.
Have a nice day.
