ProjeQtOr free project management software - [SOLVED] start -start dependency - ProjeQtOr
22 Apr 2021 07:35 #1 by Juanbeizh
i'm trying to understand how planning with a start-start dependency works ..
User guide says :
Start-StartThe successor can not begin before the beginning of the predecessor. Anyway, the successor can begin after the beginning of the predecessor.
So while making a start-start dependency between tasks A an B, B should not start before A.
But this is not happening
I tried other schemes (end-start and end-end) successfully.. but no way with start-start
Planning mode on task B set to "As soon as possible" or "Fixed duration" does not change anything.
Does anyone kow why and how to fix it ?
Thanks Juan
22 Apr 2021 10:48 - 22 Apr 2021 10:49 #2 by Flou
Replied by Flou on topic start -start dependency
it is an issue, ticket #5463  is recorded.
This fixed will be available very soon on V 9.1.3 .
Last edit: 22 Apr 2021 10:49 by Flou.
The following user(s) said Thank You: Juanbeizh
22 Apr 2021 11:09 #3 by Juanbeizh
Replied by Juanbeizh on topic start -start dependency
Ok Thanks !
Juan
