ProjeQtOr free project management software - Refused to display 'https://...' in a frame because it set 'X-Frame-Options' to - ProjeQtOr
15 Apr 2021 18:39 #1 by clauch223
Helo,
I'm getting the error:
Refused to display 'https://...' in a frame because it set 'X-Frame-Options' to 'deny'.
could you help me with this?
thank you.
15 Apr 2021 18:52 #2 by babynus
It seems you have a Add-Blocker.
Try and disable it or grand projeqtor to use iFrames.
15 Apr 2021 19:41 #3 by clauch223
Thank you,
Could you tell me, how do I grant projeqtor to use iFrames?
15 Apr 2021 23:02 #4 by clauch223
I think X-Frame-Options was forced in by ssl.conf, but now I can use it.
