ProjeQtOr free project management software - [SOLVED] Planning not saved in 9.1.1 - ProjeQtOr
09 Apr 2021 18:57 #1 by pipobru
when i would save a planning reference i have this error:2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERREUR: la colonne « idleave » de la relation « plannedworkbaseline » n'existe pas
LINE 1: ...TO plannedworkbaseline (surbooked, surbookedWork, idLeave, m...
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] For query : INSERT INTO plannedworkbaseline (surbooked, surbookedWork, idLeave, manual, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, idBaseline)
SELECT surbooked, surbookedWork, idLeave, manual, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, 91 FROM plannedwork as PlannedWork
where idProject in (0, 199)
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] Strack trace :
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #0 Sql->query called at [/home/projtma/public_html/model/persistence/SqlDirectElement.php:83]
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #1 SqlDirectElement->execute called at [/home/projtma/public_html/model/Baseline.php:115]
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #2 Baseline->copyItem called at [/home/projtma/public_html/model/Baseline.php:77]
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #3 Baseline->saveWithPlanning called at [/home/projtma/public_html/tool/savePlanningBaseline.php:64]
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERREUR: la transaction est annulée, les commandes sont ignorées jusqu'à la fin du bloc
de la transaction
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] For query : INSERT INTO plannedworkbaseline (surbooked, surbookedWork, idLeave, manual, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, idBaseline, isRealWork)
SELECT 0, 0, idLeave, manual, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, 91, 1 FROM work
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #1 SqlDirectElement->execute called at [/home/projtma/public_html/model/Baseline.php:123]
2021-04-09 18:33:57.159 ***** ERROR ***** [V9.1.1] #3 Baseline->saveWithPlanning called at [/home/projtma/public_html/tool/savePlanningBaseline.php:64]I work with postgresql database.
Very thanks for this tools, it is very very good and efficiant !
Bruno.
09 Apr 2021 19:02 #2 by babynus
Replied by babynus on topic Planning not saved in 9.1.1
This is fixed on V9.1.2
The following user(s) said Thank You: pipobru
14 Apr 2021 11:55 #3 by pipobru
Replied by pipobru on topic Planning not saved in 9.1.1
Thanks ! is perfect with the last update.
