ProjeQtOr free project management software - [SOLVED] Project planing sorted by ID - ProjeQtOr
09 Apr 2021 15:59 #1 by Jack
I would like to edit my project planning sorted by sub-projects ID and not WBS numbers.
Could you, pls, explain me how can I do that.
Thanks in advance.
Jack
09 Apr 2021 16:37 #2 by babynus
You cannot.
Planning show the WBS.
So if you want to see a specific order, you need to sort projects, and so change WBS.
09 Apr 2021 17:17 #3 by Jack
Replied by Jack on topic Project planing sorted by ID
Thanks for your answer.
How can I change the WBS. The field seem to be filled automaticly.
Thanks in advance for your cooperation.
Rgds, Jack
09 Apr 2021 17:33 #4 by babynus
Only way to change the WBS is to reorder projects or activities with Drag & Drop on Gantt view.
09 Apr 2021 17:54 #5 by Jack
Thanks you.
Every things are fine !
Rgds, Jack
