ProjeQtOr free project management software - Project and Activities created with "En Pause" Status - ProjeQtOr
07 Apr 2021 20:39 #1 by Jack
Bonjour,
Je suis nouveau sur Projeqtor. J'ai installé le logiciel il y a à peine une semaine.
J'ai pu créé quelques projets et leurs associer des activités en faisant varier l'état de l'activité.
Cependant, lors de la création de certaines activités l'état "Pause" est imposé à la création et il n'est plus possible de changer cette état.
Pouvez-vous juste m'éclairer sur cette étape.
Merci d'avance de votre support.
Cdlt, Jack
08 Apr 2021 09:15 #2 by Arkhanje
Hello to you,
As a new user you have found your way to the forum and we are delighted. On the other hand it would have been even more satisfying if you had started with the rules of the forum! Please write in English so that we can all enjoy!
See you soon for more ;)
08 Apr 2021 13:41 #3 by Jack
Hello Arkhanje,
Many thanks for your reply.
My query is about a the field "Status" that is mandatory for each project and activity.
I used now the last version (9.1.2).
When I create a new project or a new activity the status is set-up with the value "En Pause".
I don't any possibilty to change it in "In progress" or "Close" for example.
I had the opportunity to do that in the prior version for some case. But now, I don't now what I need to do to change the value of the field "Status".
Many tanks in advance for your helps.
ibb.co/Fs9rQ8h
Jack Pierre-Marie
08 Apr 2021 13:51 #4 by Jack
Another thing, when I tried to change it, I got a pop-up error message :
Invalid Controls
The field "Status" is mandatory
The workflow does not allow you to move this item to this status.
I work now with the admin account for information.
Thanks in advance for your helps.
  ibb.co/BnFdV0f
Regards, Jack PM
09 Apr 2021 16:24 #5 by babynus
Check sort order for statuses.
Pause must not be the first one.
