ProjeQtOr free project management software - [SOLVED] Link Project Product & Product Version: closed state - ProjeQtOr
[SOLVED] Link Project <> Product & Product Version: closed state
20 Mar 2021 01:25 - 20 Mar 2021 01:25 #1 by Tony44
On a project, 'Configuration' section, we can link products and product versions.
On these links, it is possible to check a "closed" state, as below :
What are the expected behaviors / results when this box is checked :
- on the Project <> Product link ?
- on the Project <> Product version link ?
Is it expected that the product or version whose link to the project is closed is no longer available on the elements of the project ?
For example, the product version would no longer be offered in the 'original product version' and 'target product version' fields of a ticket for this project.
I see this is not the case, is this an issue ?
Thanks !
Tony44
Last edit: 20 Mar 2021 01:25 by Tony44.
21 Mar 2021 13:56 #2 by babynus
Thiks is entended to work as you describe.
It it doesn't it is an issue.
We'll have a look.
22 Mar 2021 01:06 - 22 Mar 2021 01:21 #3 by Tony44
Ok, Thanks.
Likewise, the "start date" and "end date" fields of these links are not taken into account : the product and the product version are available outside the validity period of the link defined by these dates.
Tony44
Last edit: 22 Mar 2021 01:21 by Tony44.
07 Apr 2021 23:02 - 07 Apr 2021 23:04 #4 by Tony44
In V9.1.2, the closed link is now well taken into account.
However, the “start date” and “end date” fields of these links are still not taken into account: the product and the product version are available outside the validity period of the link defined by these dates.
Tony44
Last edit: 07 Apr 2021 23:04 by Tony44.
09 Apr 2021 15:30 #5 by babynus
These dates (displayed on project for linked versions) is not date for the link.
These are for information about dates of version. They have no impact on link availability.
09 Apr 2021 23:56 #6 by Tony44
Alright, that's fine with me.
In fact I had understood the opposite in the user manual :
Tony44
