ProjeQtOr free project management software - Add Product Code in Requirements and Documents Reference - ProjeQtOr
15 Mar 2021 22:34 #1 by tongax
I would like to know if it is possible to add in the elements reference (also in documents reference) the product code ( {PROD} ).
Thanks you.
16 Mar 2021 14:34 #2 by babynus
No,
and it's not planned as this would require to set the Priduct as required on documents.
(cannot set a reference based on code that may not be defined)
