ProjeQtOr free project management software - [SOLVED] V9.0.3 -> V9.0.4 charset issue - ProjeQtOr
04 Feb 2021 09:17 #1 by lo44
I have just upgrade the V9.0.3 Projeqtor version to V9.0.4, and all items with char like é,à,è....  (ie : Activity name "Réunion") are not visible now (ie in planning view).
The value "Réunion" is correct in DB.
thanks for your help.
Best regards,
Laurent
05 Feb 2021 10:49 #2 by Flou
Replied by Flou on topic V9.0.3 -> V9.0.4 charset issue
have you correctly clear the cache ?
Your  DB is encoded in utf8 ?
05 Feb 2021 12:19 #3 by lo44
Replied by lo44 on topic V9.0.3 -> V9.0.4 charset issue
thank you for your help.
I have installed Projeqtor 9.0.3, with a fresh database using WampServer 3.2.3 using default settings.
Then, 2 days after, I saw a new version 9.0.4. So I have replaced the old Projeqtor files by the version 9.0.4.
When I have started again Projeqtor (9.0.4), I discovered that all text with special letters (à, é, è, ...) where not displayed by Projeqtor 9.0.4.
The database was created using "utf8_general_ci" format.
/BR
05 Feb 2021 12:27 #4 by lo44
hi
same result by clearing the chrome cache.
/BR
05 Feb 2021 22:10 #5 by babynus
Check file parameters.php (its location is set on file tool/parametersLocation.php)
this file should contain
$enforceUTF8 = '1';
08 Feb 2021 08:21 #6 by lo44
thank you, now it's ok.
BR
Laurent
