ProjeQtOr free project management software - [SOLVED] Rights on a project ? - ProjeQtOr
02 Feb 2021 17:34 - 03 Feb 2021 11:55 #1 by sharky
Is it possible, as an administrator, to change the rights on a project?
Or even change the owner / manager?
Currently I see it (Not on all screens, only dashboard.), but I cannot modify it or add activities/tasks.
I am an administrator and the message is: you do not have the rights.
I created this project for another user (manager), then I added myself as a resource as a project manager...
Thank you
Last edit: 03 Feb 2021 11:55 by sharky.
03 Feb 2021 10:48 #2 by Arkhanje
Replied by Arkhanje on topic Rights on a project ?
Yes of course, the administrator can change this data. globally the administrator can do everything except if he himself takes away the rights.
Access and visibility rights on a project are made at the profile level on the project and not on your default profile.
You can be administrator but if you are only PL on this project then you inherit the rights of this profile.
It is therefore necessary to unlock the CRUD rights on the activities (Authorizations> rights dependent on the project) for the project manager profile to be able to modify or create them.
Have a good day
03 Feb 2021 11:53 #3 by sharky
Replied by sharky on topic Rights on a project ?
Thank you for your reply.
I had to use the "admin" account. My account with the same rights could not access it.
In the project, I changed my role and OK
thanks
