ProjeQtOr free project management software - [SOLVED] Animation and other questions - ProjeQtOr
29 Jan 2021 12:38 #1 by Coasterman
Thank you first for the new design.
I have some questions:
1) How can I turn off the animations (as user or global).
It cost me and new users a lot of time going trough the trees, searching for some toppics, if they are not jet in the favourits lists (thank you for that), because it is not shown the full tree anymore where I can select other toppics directly.
2) Global parameters --> display in fading mode Yes/No
What does this setting change? I couldn't see any differnce neither in Firefox nor in edge...
3) How can format of the representetd dates be changed into MM.DD.YYYY
4) Where to check if comma "," or dot "." is used for numbers?
(I've seen in the Forum that in some configuration it might be ",")
5) How are the colors chosen? Some combinations of main and secondary color lead to results where for example the arrow cannot or hardly be seen anymore. (specially for people with a color weekness).
01 Feb 2021 11:08 #2 by babynus
It is not possible to remove the animation.
We'll have a look if we can introduce parameter to accelerate it.
NB : when you search for topics, use the search menu feature
This is not used anymore.
This parameter was removed from user parameter, but left on global parameter. This will be fixed.
This is a user parameter
It will change automatically depending on behavious on your browser
We propose 4 exemples, but everyone can define his own color, to fit enterprise graphic chart or to fit own taste or to distinguish connected user or instance
Note that default selection on global parameters will be displayed as 4th proposed values, to adapt to brading colors.
01 Feb 2021 14:53 - 01 Feb 2021 15:06 #3 by Coasterman
Thank you for the reply
Unfortunatley the date canno't be formated at the user parameters. It only accepts the following predefinde three formats
MM/DD/YYYY
DD/MM/YYYY
YYYY-MM-DD
By the way:
Is it forseen for the left hand menu, that only selected topics and topics with subtoppics change the collor? Or should also the topic which is below the mouse change the collor, if it has no subtoppics (select frame). In the moment it shows teh star to select as "favourite"
Last edit: 01 Feb 2021 15:06 by Coasterman.
01 Feb 2021 15:54 #4 by babynus
I did'nt notice you want . (dot) instead of / (slash).
No this cannot be changed.
Time to create page: 0.104 seconds
