ProjeQtOr free project management software - Is their any way to calculate real hours and disable the manual entry - ProjeQtOr
02 Nov 2020 08:16 #1 by divyesh
Please suggest is their any workaround so that we can add formula to calculate real work from done and handled field and disable user manual entry.Please suggest code level entry for same if possible.
03 Nov 2020 15:03 #2 by babynus
Activate Global Parameter "Manual progress of Fixed planning activities"
Then only use Fixed duration planning mode, without assignment.
You'll have access to enter manual progress and real work will be calculated as validated x progress
